I get no field to paste in your store …?! I get a warning to connect to not official sores..! did umbrel changed something? What could it be..?
Kind regards coinolli
Strange. I am on the latest Umbrel version. What is the exact error message you see (copy/ paste it if possible)? I’ll see if I can track it down. If anyone else more familiar with Umbrel knows about this, please chime in as well.
Community App Stores
Community App Stores allow you to install apps on your Umbrel that may not be available in the official Umbrel App Store. They also make it easier to test beta versions of Umbrel apps before developers release them in the official Umbrel App Store.
Learn more
Anyone can create a Community App Store. The apps published within them are not verified or vetted by the official Umbrel App Store team and could potentially be unsafe or malicious. Exercise caution and only add app stores from developers you trust.
Location is Germany, browser is safari…
any idea…?
That is the dialog which opens when you click on Community App Stores. It seems to be missing the page formatting and the bottom half of the dialg.
Maybe try clearing the cache and hard reloading? I also tested on Safari and didn’t see the problem, but might be worth trying another browser just to see.
What version of UmbrelOS are you running?
1.7.4
everything works fine, Knots, mempool, LND, alby, electrs…
For reference, this is what that dialog is supposed to look like (the English version, but I wouldn’t expect other languages to look differently):
The styling is jacked up in your screenshot (plain “black on white” text, Umbrel desktop background image appearing oddly as a thumbnail at the top, etc, and of course the URL and Add buttons missing at the bottom)
Has anyone else encountered this before? Only things I can think of to try are clearing the cache, or loading it in a different browser. It is very odd.
will try different browsers…thanks for the infos…I come back again…
It is probably either a Safari version (or plugin) incompatibility or an issue with cached webpage data (maybe from an older version of UmbrelOS before an update).
Hello!
Mempool BIP-110 is connected to my umbrel, but after a while, the fan starts working. when I stop the pool, the fan stops working. is it possible, that the RAM of 16GB is overloaded…?
It has to work pretty hard to index all of the historical data. You can look in the Settings menu to see the resource usage. It is probably mainly using CPU than RAM, but worth checking. It takes a day or so typically to finish the indexing.
Thanks, Paul, I will check it…![]()
