Tor is failing key retrieval?
system/tor-logs:
2026-04-12T13:53:55-06:00 Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
2026-04-12T13:56:50-06:00 Received http status code 404 (“Not found”) from server 51.75.141.87:9000 while fetching “/tor/keys/fp/14C131DFC5C6F93646BE72FA1401C02A8DF2E8B4”.
2026-04-12T13:59:13-06:00 Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
Went from hero to zero on BOTH servers. Anyone notice the same?
What application are you running that generates this log? Also, what operating system is that application running on?
Start9 OS - Pure Server and a Server One
They are the StartOS system/tor-logs
Also C-Lightning is showing the same kind of activity on Tor
What are the symptoms you see in conjuction with these logs? Is tor broken across the board (for example, can’t connect Sparrow wallet either)?
I think the lines Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query are normal. Or, to be more specific, I see that message repeated frequently in the logs on my server even when everything appears to be working working completely fine. If I am interpreting the message correctly, I think it is saying a service that it tried to connect with was temporarily unreachable-- which presumably happens frequently for Lightning peers which are not constantly up.
I’ve not seen the line Received http status code 404 (“Not found”) from server 51.75.141.87:9000 while fetching "/tor/keys/fp/14C131DFC5C6F93646BE72FA1401C02A8DF2E8B4". Do you recognize that IP 51.75.141.87?
No I dont. The Pure log how a different IP
Received http status code 404 (“Not found”) from server 137.74.46.232:9001 while fetching “/tor/keys/fp/14C131DFC5C6F93646BE72FA1401C02A8DF2E8B4”.
so the key is??? I notice they are the same…2 different servers.
Ill take a look at the peers
14C131DFC5C6F93646BE72FA1401C02A8DF2E8B4 is an “v3ident” signature for a public Tor directory server. It is widely documented (for example, here are some slides that mention it in the context of “how tor works”)
This seems to have worked itself out. I figure it’s an external dependency again…especially with Core Lightning. Depressing
