I was trying to install Thunderhub so I could get on the same page as my counter part but I get this error:
My LND node is more current (19.2) than ThunderHub supports. Are there any dangers here?
I don’t use Thunderhub myself, but my guess is that since this StartOS wrapper project is managed by a community member rather than Start9, they probably just need to update the max version listed in the config after running tests. I assume the risk is low. That said, if it stays this way for a long time, that could be an indication that the StartOS wrapper project might have been abandoned by the maintainer.
Yeah, the app is looking for a version number which has been superseded by LND’s latest upgrade. No harm running the app, there is a newer version of it on github but I prefer to wait for the official start9 release myself. ThunderHub has worked fine for me since the LND upgrade, despite the warning message.
Thank you very much gentlemen
Funnily enough a new version of Thunder Hub came out recently and the error is now cleared. Took away the temptation to install the github version.
