Hi Paul, I cant find the right iso…?!
What I downloaded from github start-cli v2.5.0 I am not able to open it with baletcha…?
Cant you give som advice please?!
Kind regards
Kind regards
Start9 have started putting all of their software releases (start-cli, StartTunnel, start-registry, StartOS, etc) all into one big “mono repo” on Github, which is confusing a lot of folks. All you have to do is just scroll down on the releases page for a while until you find the latest release for StartOS (currently 0.4.0.3).
Hi Paul, I found it - thank you!!
The last help please:
I need Seedsigner OS for Blake2b…
Do you have the standard SeedSigner, or the SeedSigner Plus (with the big screen)?
The standard SeedSigner and the Plus differ mainly in display size, so which OS image fits depends on which board and screen you actually have. If it’s the standard model with the small LCD, the usual SeedSigner image should be the right match; the Plus may need a build configured for its larger panel. Best to check the screen model before flashing, since the Blake2b support you need is tied to the firmware version rather than the display itself.
Standard seedsigner…
and another question:
I installed umbrel on beelink 16GB/256GB but I have also an external 2TB ssd nvme.
should I installed prune (Blake companion) or full with using the chain on external drive, if possible…?!
Target is using sparrow Blake2b/ Shrike and least the seedsigner…
Thanks in advance…
