Start9 node with both SHA-256 and BLAKE2B chains
Is it possible to run both a Knots (blake2b) and Knots (preRDTS) or Core on a single Start9?
Yes, I have created “Companion” nodes which run alongside the normal slot for Knots/Core. They run as pruned by default (can be run as full nodes if you have 4TB of space on your server to support two full nodes). There are other threads on the forum here where I outlined the steps to set this up. I’ve been promising to record a video tutorial on this, so I’ll do that soon (I mainly wanted to finish porting LND to the BLAKE2b chain so I could include it in my “full stack”, and that is now completed)
I’m thinking of selling my sha256 coin soon. I have my start9 with a blake2b full node. To make the transaction to the exchange, I just install your bitcoin knots sha256 companion and also electrum pruned? Am I also right in thinking that to do replay protection I can simply add a large enough op_return with sparrow on the sha256 transaction thats being sent to the exchange?
A large OP_RETURN on the SHA256 chain is more difficult than a Unified Sighash on the BLAKE2b chain (since Sparrow doesn’t have an interface for that). I would replay-protect from the BLAKE2b side. Then once you confirm that the stacks are disconnected (by sending a small amount to another wallet and confirming it doesn’t replay), you can move the SHA256 sats to the exchange.
thank you for the tips. I havent put much research yet on how to do it but I’ll look more into it.
This would probably be one of the most valuable videos you could do next as I am sure there are many who want to disconnect the chain addresses and no longer have to fear replay attacks :folded_hands:
One problem is I don’t have any replay-unprotected UTXOs to demonstrate with. It would be talking in theoreticals, which isn’t ideal for a tutorial. Maybe still worth it, IDK.
i have a coinos wallet with some btc in it from before the fork. I can send you a bit if this will work
ah I see; okay. where would you recommend are the cleanest steps you have seen e2e for applying replay protection to BTC as once that’s done I assume XBT will have it too. I have not gone near Shrike yet as it felt still too early in terms of maturity and hacks since it seems we are all under attack now certainly cold wallet vulnerabilities are all being well exploited.
I don’t have a clean guide, but basically you could follow what Matthew Kratter showed on one of his videos for adding a large OP_RETURN using electrum (since Sparrow doesn’t support it). I would use that in a process similar to what I mentioned for Shrike.
  1. Send a very small amount of your stack (not dust, but no need to risk anything here) to a new hot wallet
  2. Load the hot wallet in electrum, and send it back to the original wallet with a large OP_RETURN added (making it invalid on the BLAKE2b chain)
  3. Consolidate your stack in the original wallet, combining it with the UTXO from step 2.
You could do this as one large consolidation, or in whatever sized chunks you want for your final UTXOs.
Since you won’t be running Shrike, the best way to confirm replay protection is to load the consolidation transaction(s) from step 3 into a BLAKE2b mempool explorer (such as mempool.guide) to make sure they are not found. If they are found, then you know you did something wrong, so go back and check each step.
Hi Paul, I already run blake2b full node, knots, fulcrum, and mempool guide. I loaded the pruned companion electr, mempool.space, and still waiting for Bitcoin knots (sha256) companion to finish,76% after 5 days. In the mean time I tried to load a wallet (pre fork) to Shrike to replay protect the coins in there. But it would not load. “Error loading…” Wonder what I can do? I’m happy to pay for your time to guide me. Thank you.
Did you connect Shrike to the companion? If so, it won’t work until the node has completed the IBD and electrs pruned has completed its index. It seems like your system is a bit slower than some, so expect that to be quite a long wait.
Shouldn’t shrike connect to bitcoin knots:29.4.2:4 blake2b which is already fully running? I already have created a new shrike wallet. The wallet works great. The companion bitcoin knots still loading is for sha256. Just having trouble loading a wallet from prefork.
Sorry, I read your post backwards. In that case, not sure what is wrong with Shrike.
If you are connecting Shrike to Fulcrum via the LAN IP, maybe try connecting via Tor to see if it has any difference.
can you give me instructions on how to do that? thanks
Yes, for Fulcrum, go to Interfaces > Electrum (SSL) and under the Tor section add a new Onion service if there isn’t one already. Make sure the SSL radio is enabled.
Then copy the new onion service URL, and hop over to Shrike. Go to File > Settings and open the Server tab. Past the onion service URL into the “URL” field (not the proxy url field).
Then Test Connection to make sure it works. If you get a handshake failure message, then it is probably because you updated StartOS, which mints new certs. If that happened, you will need to close Shrike, move the certs which are under ~/.shrike/certs/ to somewhere else, and then start Shrike back up to re-test the connection.
Hello Paul and community.
I’m having a Bitcoin Knots (SHA256) Companion issue insofar as the update timeline to get all up to date.
My goal: run both Blake2b and legacy BTC on same Start9 (version0.4.0.2) node with reasonable performance.
My hardware: Dell Optiplex 7040 micro tower with an i5 cpu, 8GB RAM, 2TB SSD.
Originally intended to just run the lagacy chain before the BIP 110 saga, confirming mining centralization on legacy chain.
What I have done so far:
Installed successfully:
  • Bitcoin Knots 0.4.0.2
  • Fulcrum (BLAKE2b)
    #blake:2.1.3:1
  • Tor 0.4.9.14:1
Hardware current performance:
CPU averages 33% RAM: 53% Storage: 720 GB free
My perceived problem (I am not an expert) is the extremely slow updating of the Bitcoin Knots (SHA256) Companion
#knotsprerdts:29.3:31
My MAPLE AI tells me to share this info:
LAN peer connected, peers healthy, resources unsaturated, ~2.5 blocks/min at post-assumevalid heights
Currently testing pausing Fulcrum, but does not seem to make a difference after 28 minutes.
What can I do? ( is there anything tha can be done?) to speed this crawling to a quicker pace?
Thank you.
8 GB RAM is the likely bottleneck, with Tor-only peers possibly a second.
I recommend stopping all services (if feasible and you aren’t using them) and rebooting the server. Wait a few minutes for it to fully start up and complete any tasks.
Then start up just the Knots companion, and leave only it running until it is fully synced. Watch to make sure Knots companion isn’t in a restart loop or has errors appearing in the log.
Will do.
Thank you for being a great resource.
