Separate XBT from SHA256 BTC wallets
Hi Paul
I now have my all my BTC Wallets loaded on my Shrike Wallet, hardware and software wallets to include Sparrow.
I have a SeedSigner and a microchip formatted for both the Blake2b and the SHA250 chain.
What are the steps I need to take to safely move my xBT off my SHA250 Wallets to my Blake2b wallets?
Thank you
When you say you have a microchip formatted fo both the BLAKE2b and the SHA256 chain, do you mean you have two separate chips (one with the new BLAKE2b seedsigner image and one with the original stock seedsigner image)? I don’t want to confuse you in the steps if you are just using one chip for both as opposed to a separate chip for each.
Yes, I have 2 separate chips one formatted for the Blake2b Wallets and another for SHA256 Wallets. I interchange them out, after powering down the SeedSigner to access and sign transactions on either Blake2b or SHA256.
Got it. So the process will look like this, if I understand what you are trying to do here:
  1. Create a new cold wallet from your SeedSigner BLAKE2b (dice rolls is best, but the camera entropy feature is good if you point the camera at some complex system)
  2. Connect that new cold wallet to Shrike
  3. Open a wallet with BLAKE2b coins you want to move in Shrike
  4. Send them to the new wallet from step 1. Make sure Shrike shows that the transaction will be replay protected (if it doesn’t show this, then you are missing a configuration step in Shrike for the wallet you are sending coins from)
  5. Open the same walet in Sparrow, and make sure the coins did not move. If they did move, then you missed a step somewhere (see my comment on #4 as the most likely cause), and you will need to repeat the process from step 1 with a new cold wallet once you identify what you missed.
  6. Repeat for every wallet that you want to move. Hot wallets are easier (Shrike should automatically mark them as replay protected without the extra configuration step)
BTW, if you are concerned about entering your seed phrase into the BLAKE2b Seedsigner software, there is another method you can use which doesn’t require it. Sounds like you already have from your first post (“I now have all my BTC Wallets loaded on my Shrike Wallet”), but let me know if I misinterpreted you.
Hi Paul
I was successful in moving xBT off my first wallet, Bitbox. I ended up just loading my Seed in my SeedSigner on Blake2b. I did a small amount, it took awhile for the transaction to confirm, but nothing moved on my SHA-256 BitBox wallet. I was able to withdraw the rest of the xBT without any issues.
I think I will just stick with loading the Seeds into the SeedSigner, it works really well. On my Ledger Wallet I have 2 (two) “sub-wallets”, they don’t show up in my total balance. I will probably move the Sats to another wallet where I can see the xBT. I hate moving the balances to another wallet because they have good historical data - Celsius Recovery Records.
Thank you for all assistance and advice! And I appreciate your patience and clarification of terminology.
Once I get this done I’ll need to work on plans for Lighting on xBT which Matt has highlighted on his channel, and xBT Mining options. I currently am using a NerdQaxe, SHA256. I think Matt talked about renting hash, maybe the best option.
Thank you again Paul!
Awesome. Happy to help you out with whichever area you want to explore next. There are a lot of cool things happening in the lightning space, and renting rings for SHA256 sats to mine for you on the BLAKE2b network is a good two-fer if you are planning to DCA some of your SHA256 position into BLAKE2b (helps decentralize mining in the process, as opposed to simply trading on an exchange).
