All wallets where created - imported same way. The only thing is that non transactions done with Shrike are visible on mempool.space. So there are only in Shrike wallet. There where done on Shrike connected to your app Elecrts Pruned using Bitcoin knots companion. And yes, when imported to Shrike, all previose (old) transactions where there from sparrow wallet.
Ok, I am assuming the answer here is yes.
Next, you did one transaction in Shrike to send a small UTXO to the hot wallet. This would show as an outgoing transaction in Shrike for the Ledger cold wallet. Did that same outgoing transaction appear in Sparrow for the Ledger cold wallet?
No, did not. Just checked old the transactions (sparrow) and compared them to imported once with shrike. They have different times and different block numbers but same transaction IDs. Two even different date
Ok, those are all recent transactions. Anything from before the chain split?
My guess here is that because you have some transactions that are replay-able, and some that are not, the small UTXO happend to not be replay-able. This is fine. It just means the small transaction never replayed on the SHA256 chain, so steps 6 and 7 are not necessary.
As long as you properly followed step 4 (replay protected showing greeen), you should be good.
Transaction before are completely identical. Yes I did the 4th transaction in Shrike replay protected. (Was green). So now when I do transaction in sparrow, should not overwrite those in shrike. That should be a proof as well OK
