Is it possible to solo mine and pool mine simultaneously if you have multiple ASICS ? and,
How difficult and what mandatory changes are required to switch between, say, pooled mining and solo mining? And, are the steps different than going from solo to pooled? I have stumbled through solo to pooled (with Convoy), but an A,B,C specific steps would be a good guide for all of us new miners.
I had that backwards, currently running pooled on Bitcoin Knots and Datum Gateway; so will drop one ASIC there and then (install?) both Bitcoin Knots (Blake2B) and Datum Gateway (Blake2B). And configure the single miner there. Is that correct? (None of my services now show Blake2B now.)
The Bitcoin Knots (Blake2B) finished syncing overnight and I have successfully split the hash between the miners so that one half is solo mining and the other half is pool mining. And must say that it was very informative and a good learning and familiarity experience. Could not have done it without Paul, THANK YOU, SIR !
