I published one final update to Mempool BIP 110 before mandatory signaling starts tomorrow. Update if you want to see all the bells and whistles when mandatory signaling begins (it will rebuild its cache to collect some new data points). If you are running two nodes following each set of consensus rules (a Knots node and a Pre-RDTS Knots node for example) install Mempool BIP 100 on both, so you will be able to visualize a chain split if one were to occur.
