Lightning peers that accept small (~150k sat) channels
This is a vetted list of 15 lightning routing peers confirmed to accept channel opens
at ~150,000 sats — well below the 1M-sat-plus floor that most
established routing nodes require. Useful if you’re spinning up a small
LND node, opening your first inbound channel, or building out
diversity without locking up large amounts of on-chain BTC.
Every peer below was empirically tested: I connected to them, sent
a real 150,000 sat funding transaction, and observed the channel accept.
The data on fees, channel counts, and outbound enable rates is read
straight from public gossip. Channel handles you, the reader, can open
with these peers right now (subject to the usual gossip-staleness
caveats — see caveats below).
Snapshot date. All numbers below are current as of 2026-06-27.
Lightning is a living network; peers add/drop channels, rotate ports,
retune fees, and occasionally go offline. Reverify before opening if
the dates here are more than a couple of weeks old.
Why this list exists
The Lightning Network’s biggest routing operators — LNBiG, River
Financial, ACINQ, lnmarkets.com, OKX, IBEX, etc. — typically reject
channel opens below 400,000 - 1,000,000 sats. That’s a real barrier for:
  • New operators standing up their first node who don’t want to
    immediately lock up the equivalent of $500+ in a single inbound
    channel.
  • Small/mobile wallets opening direct inbound channels for receive
    liquidity.
  • Existing operators building out peer diversity (geographic, AS,
    software) with a smaller-than-headline-capacity budget.
The 15 peers documented here all accepted a 150k sat open. Most are
mid-sized routing nodes that actively maintain channels with popular
large hubs
, so a channel with one of them gives you incoming-routing
access into the broader network without requiring you to open directly
with the big operators.
How to read this list
Entries are ordered cheapest-typical-receive-fee first. Every peer
on this list passed two empirical checks — they accepted a small open,
and gossip shows they peer with multiple top-tier routing hubs — so the
remaining axis you’re choosing on is fee. The plain-English summary in
each entry captures the trade-offs.
Labels used:
Fee tier (median fee_rate_milli_msat on the peer’s outgoing edges) Label
< 50 ppm Very low fees
50 – 500 ppm Low fees
500 – 2,000 ppm Moderate fees
> 2,000 ppm High fees
Top-20-hub connections Label
≥ 30 Highly connected
20 – 29 Well connected
10 – 19 Adequately connected
< 10 Limited connectivity
Outbound enabled ratio: the share of the peer’s own gossiped
channels on which they currently have outbound forwarding enabled.
A healthy router sits at 95%+. Anything below ~80% is a yellow flag —
they may accept your open but not actively route HTLCs through the
channel. Every peer here is at ≥36% (and most are ≥87%); I explicitly
call out the lower-end ones.
Quick reference
# Alias Median fee Channels Capacity Location
1 Babylon-4a :star: 0 base + 20 ppm 284 17.98 BTC Linode US
2 krut42 :star: 0 base + 0 ppm 33 2.37 BTC Selectel Russia
3 New Horizons :star: 0 base + 15 ppm 136 6.62 BTC Hetzner Germany
4 connect-to-this-node-please 0 base + 65 ppm 90 22.76 BTC AWS Oregon
5 ORANGEIRON 0 base + 138 ppm 60 5.19 BTC Vultr
6 BavarianBitcoinBank 0 base + 159 ppm 112 1.91 BTC IONOS Germany
7 Porcino 🍄‍🟫 0 base + 200 ppm 93 14.31 BTC Netcup Germany
8 hashposition.com 🔵 0 base + 252 ppm 64 2.90 BTC DigitalOcean
9 Operator-pair: hex aliases 0 base + 500 ppm 214 + 191 90.77 + 97.15 BTC AWS Oregon
10 absolute.money 0 base + 777 ppm 129 15.25 BTC (unknown clearnet IP)
11 HydraNode 329 base + 208 ppm 89 6.94 BTC RU-CENTER Russia
12 CoinGate :warning: 1 sat + 1 ppm 1,321 16.62 BTC AWS Frankfurt
13 DedanKimathi 1 sat + 100 ppm 48 14.90 BTC AWS Cape Town
14 points-nexus 1 sat + 1,300 ppm 52 31.80 BTC AWS Oregon
15 Chessa ✨ 1.5 sat + 326 ppm 31 5.19 BTC AWS Oregon
:star: marks my three recommended defaults — well-rounded across fees,
connectivity, and routing health. :warning: marks CoinGate, which has a
remarkable headline fee but a marginal outbound-enabled rate; see its
entry for full context.
The peers
1. Babylon-4a
Pubkey 0340cfadaa3324e0dd176a9969be050114278f93260e1b6333bd2a2a2ea03c64a3
Socket 45.33.71.93:9739 (Linode US — note non-standard port 9739, not 9735)
Channels (gossip) 284
Capacity (gossip) 17.98 BTC
Top-20-hub connections 24
Typical fee_base_msat 0 (median across 264 active edges)
Typical fee_rate_milli_msat 20 ppm (median; min=0, max=9,000)
Typical min_htlc_msat 1,000 msat (1 sat)
Typical time_lock_delta 100
Typical max_htlc_msat ~42 M msat per HTLC (median); wide variance
About this peer The cheapest peer in the list when you factor in routing-depth and connectivity together — 284 gossiped channels and almost 18 BTC of capacity backing them. A solid default for receive liquidity at a small-channel price point.
2. krut42
Pubkey 02961ed16db648f99ff5aa121a263420911d6b6011794f2a99b79397b5e8b2eed4
Socket 193.124.56.148:9735 (Selectel, Russia)
Channels (gossip) 33
Capacity (gossip) 2.37 BTC
Top-20-hub connections 16
Outbound enabled 33 / 33 (100%) — every edge active
Typical fee_base_msat 0 (median; min=0, max=1,000)
Typical fee_rate_milli_msat 0 ppm (median; min=0, max=475)
Typical time_lock_delta 80
Typical max_htlc_msat ~5.9 M sat per HTLC (median); up to ~12.9 M sat
About this peer Cheapest median fees of any peer here — half their outbound channels are completely free to route through. Smaller than Babylon (33 vs 284 channels) so onward path diversity is more limited, but 100% of edges are enabled (rare) and the operator is in Russia, giving useful geographic diversity if your other peers are US-hosted.
3. New Horizons
Pubkey 03e86afe389d298f8f53a2f09fcc4d50cdd34e2fbd8f32cbd55583c596413705c2
Socket 5.75.184.195:43313 (Hetzner Germany — non-standard port)
Channels (gossip) 136
Capacity (gossip) 6.62 BTC
Top-20-hub connections 14
Outbound enabled 133 / 136 (98%) — near-perfect routing posture
Typical fee_base_msat 0 (median, min=max=0 — zero base on every edge)
Typical fee_rate_milli_msat 15 ppm (median; min=1, max=4,444)
Typical time_lock_delta 40 (median; min=40, max=80 — shorter than the LND default, route-friendly)
Typical max_htlc_msat ~4.95 M sat per HTLC (median); up to ~16.6 M sat
About this peer Second-cheapest median fee in the list and substantially better-connected than the lowest (krut42). The combination of zero base + 15 ppm + 98% enabled + a 40-block time_lock_delta is the most route-friendly profile of any peer here — well-suited for both small payments and longer multi-hop routes. Strong recommendation alongside Babylon-4a; pick either depending on whether you prefer larger raw capacity (Babylon) or lower fees + better edge utilization (this one).
4. connect-to-this-node-please
Pubkey 026c2595bddf44ca1eadb65ad26942b325616690d104442f8560a7faaf67c4c323
Socket 54.244.234.100:20078 (AWS us-west-2, Oregon — non-standard port)
Channels (gossip) 90
Capacity (gossip) 22.76 BTC
Top-20-hub connections 33 — the highest of any peer in this list
Typical fee_base_msat 0 (median across 86 active edges)
Typical fee_rate_milli_msat 65 ppm (median; min=0, max=9,999)
Typical max_htlc_msat ~99 M msat per HTLC (median)
About this peer The strongest connectivity signal of any peer here — 33 direct channels to top-tier routing hubs. Best pick if you’re worried about routes being available from unusual paying nodes (an exchange in a different region, an LSP, etc.) — an extra-safe choice that costs ~3× more in routing fees than Babylon-4a.
5. ORANGEIRON
Pubkey 03a465772d45616bf6c8450a69191db8f3cf8cca19ff92138735fd5f1d436fe4dc
Socket 45.77.75.86:9735 (Vultr)
Channels (gossip) 60
Capacity (gossip) 5.19 BTC
Top-20-hub connections 13
Outbound enabled 58 / 59 sampled (97%)
Typical fee_rate_milli_msat 138 ppm (median; min=0, max=8,693)
Typical min_htlc_msat 1 msat (the lowest in the list — true micro-payment ready)
Typical time_lock_delta 34 (uniformly — the shortest in the list)
Typical max_htlc_msat ~1.2 M sat per HTLC (median); up to ~25 M sat
About this peer Strong all-rounder. The uniform 34-block time_lock_delta is the most CLTV-budget-friendly of any peer here — it leaves the maximum possible budget for downstream hops on long routes. The 1-msat min_htlc makes it usable for genuine micro-payments (Lightning’s smallest possible HTLC). Smaller per-HTLC cap than most (~1.2 M sat median) — fine for typical receive sizes, but you’d want to split a single 10 M sat payment across multiple HTLCs.
6. BavarianBitcoinBank
Pubkey 037886fe3551ab7a38f33598e96471c697da8ac6fb9d8b7b4d23708877ee831ef5
Socket 212.227.64.36:9735 (1&1 / IONOS, Germany)
Channels (gossip) 112
Capacity (gossip) 1.91 BTC
Top-20-hub connections 12
Outbound enabled 109 / 112 (97%) — near-perfect routing posture
Typical fee_rate_milli_msat 159 ppm (median; min=0, max=1,973)
Typical min_htlc_msat 1 msat (micro-payment ready, matches ORANGEIRON)
Typical time_lock_delta 80 (uniformly — LND default)
Typical max_htlc_msat ~359 k sat per HTLC (median); up to ~9.9 M sat
About this peer Solid mid-low-tier peer with pure-percentage pricing and 97% enabled outbound. Modest 1.91 BTC capacity is the smallest of the cheap-tier peers, so its routing depth is more limited than Babylon-4a or Porcino — but for typical receive sizes that’s not a constraint. Branded operator (Bavarian Bitcoin Bank). Complements New Horizons’s Hetzner-Germany via a different German provider (IONOS).
7. Porcino 🍄‍🟫
Pubkey 02f9cdc8df3f142dcef499ce66464e2697f6e80e0db4b1d49c86f3e272931191c1
Socket 152.53.106.28:19735 (Netcup, Germany — non-standard port)
Channels (gossip) 93
Capacity (gossip) 14.31 BTC
Top-20-hub connections 15
Outbound enabled 91 / 93 (98%) — almost every edge active
Typical fee_rate_milli_msat 200 ppm (median; min=0, max=2,500)
Typical time_lock_delta 144 (uniformly — higher than the LND default of 80)
Typical max_htlc_msat ~4.9 M sat per HTLC (median); up to ~48.5 M sat
About this peer One of two peers in the list with zero base fee on every single edge (the other is ORANGEIRON); fees are pure-percentage. The 144-block time_lock_delta is roughly 2× the LND default, which subtracts ~64 blocks from your usable HTLC budget — for very long routes that touch multiple high-delta hops, this could nudge a payment over LND’s 1,008-block CLTV ceiling. Solid mid-tier choice with strong capacity (14.31 BTC).
8. hashposition.com 🔵
Pubkey 02ad6fb8d693dc1e4569bcedefadf5f72a931ae027dc0f0c544b34c1c6f3b9a02b
Socket 161.35.9.253:9735 (DigitalOcean)
Channels (gossip) 64
Capacity (gossip) 2.90 BTC
Outbound enabled 55 / 63 sampled (87%) — moderate, 8 edges disabled
Typical fee_rate_milli_msat 252 ppm (median; min=0, max=2,000)
Typical max_htlc_msat ~990 k sat per HTLC (median); up to ~49.5 M sat
About this peer Pure-percentage pricing at 252 ppm median. Routing health is moderate (12.7% of edges disabled — the lower end of acceptable). Smaller per-HTLC cap than most (~990 k sat median); plenty for typical receive sizes but might force splitting on a single mid-six-figure payment. Branded operator.
9. Large routing operator-pair (hex-aliased)
A pair of clearly-sibling nodes operated by the same entity — same
uniform 0 + 500 ppm policy, same 80-block CLTV delta, same 1-sat
min_htlc, same AWS us-west-2 region, ports 10015/10016 adjacent, both
operators left their aliases as raw pubkey-prefix hex. Opening to BOTH
gives only marginal additional routing diversity since they likely
share upstream paths. For most users, pick either one (whichever
responds first).
Node A Node B
Pubkey 02a98e8c590a1b5602049d6b21d8f4c8861970aa310762f42eae1b2be88372e924 039174f846626c6053ba80f5443d0db33da384f1dde135bf7080ba1eec465019c3
Socket 54.201.244.204:10016 34.219.38.168:10015
Channels 214 191
Capacity 90.77 BTC 97.15 BTC
Top-20-hub connections 15 15
Common policy (identical fingerprint across both nodes):
Typical fee_base_msat 0 (uniformly)
Typical fee_rate_milli_msat 500 ppm (uniformly — tight, identical policy on every channel)
Typical max_htlc_msat ~5.94 M sat (Node A) / ~10 M sat (Node B) per HTLC (median)
About this operator Big-capacity routing operator (~190 BTC across the pair) with a uniform 500-ppm fee. ~25× more expensive per sat received than Babylon-4a, but the size + uniform policy suggest a serious, professionally-managed operation. Reasonable choice when you want a large stable node and don’t mind paying for it; if you want to maximize diversity within this operator’s footprint, opening with one is enough — the second adds little.
10. absolute.money
Pubkey 036635ba9a28a8ba133bb630ddf67f84b56d20073c8f2b5fca92dfa571507cd973
Socket 5.11.92.140:9735
Channels (gossip) 129
Capacity (gossip) 15.25 BTC
Top-20-hub connections 19
Typical fee_base_msat 0 (median across 124 active edges)
Typical fee_rate_milli_msat 777 ppm (median; min=1, max=5,000)
Typical min_htlc_msat 1 msat (accepts truly tiny payments)
Typical time_lock_delta 34 (across the board — unusually short; most operators use 40-144)
Typical max_htlc_msat ~7.6 M msat per HTLC (median)
About this peer Functional but pricier — at 777 ppm, you’ll pay roughly 39× more in routing fees than through Babylon-4a. A reasonable backup if the cheaper peers above are unreachable from your wallet’s gossip view. The 1-msat min_htlc and short CLTV (34 blocks) make it well-suited for micro-payment use cases.
11. HydraNode
Pubkey 02ceb27f3d4e32b83f37dff8bad8cc802dc0f380ca0193e90514ae25bc32c7542e
Socket 194.145.208.114:9735 (RU-CENTER, Russia)
Channels (gossip) 89
Capacity (gossip) 6.94 BTC
Outbound enabled 70 / 89 (79%) — non-trivial fraction of edges disabled
Typical fee_base_msat 329 msat (median; min=1, max=1,578)
Typical fee_rate_milli_msat 208 ppm (median; min=0, max=2,392)
Typical time_lock_delta 40 (median — shorter than the LND default of 80, route-friendly)
Typical max_htlc_msat ~4.95 M sat per HTLC (median); up to ~73.7 M sat
About this peer Hybrid pricing — meaningful 329 msat base plus 208 ppm proportional. For typical sub-10k sat payments the base dominates, giving an effective ~0.33 sats per payment regardless of size. Routing health (79% enabled) is weaker than most of the peers above; consider it a yellow flag rather than a deal-breaker. The short time_lock_delta (40) is a small bonus on long routes.
12. CoinGate :warning: Marginal routing health
Pubkey 0242a4ae0c5bef18048fbecf995094b74bfb0f7391418d71ed394784373f41e4f3
Socket 3.124.63.44:9735 (AWS eu-central-1, Frankfurt)
Channels (gossip) 1,321 (largest in this list — a major commercial payment processor)
Capacity (gossip) 16.62 BTC
Outbound enabled 472 / 1,319 sampled (36%):warning: 64% of edges are disabled outbound
Typical fee_base_msat 1,000 msat (uniformly — min=median=max=1,000)
Typical fee_rate_milli_msat 1 ppm (uniformly — the lowest rate in the entire list)
Typical time_lock_delta 80 (median; min=40, max=144)
Typical max_htlc_msat ~544 k sat per HTLC (median); up to ~16.8 M sat
About this peer The most attractive fee structure in the list on paper — 1 sat base + 1 ppm is essentially a flat 1-sat fee that doesn’t scale up with payment size at all. But the 64% disabled-outbound rate is a real concern for inbound liquidity: it means CoinGate may not actively forward HTLCs back to you over the channel you opened, even though the channel exists and the fee policy is published. Their 472 enabled outbound channels are a real routing surface (more than most peers here have channels total), so it’s not non-routing — but it’s a noticeably weaker enable rate than the rest of the list. Treat as a fallback choice; if you open here and find that payments to you start landing as NO_ROUTE failures, close and pick from earlier in this list.
13. DedanKimathi
Pubkey 0397391be2af48d7d61aa488d209d4767e2fcc5d0bec0f783abb4a1a2002c40186
Socket 13.245.66.35:9735 (AWS af-south-1, Cape Town — sole African peer here)
Channels (gossip) 48
Capacity (gossip) 14.90 BTC
Outbound enabled 48 / 48 (100%) — every edge active
Typical fee_rate_milli_msat 100 ppm (median; min=25, max=750)
Typical max_htlc_msat ~9.6 M sat per HTLC (median); up to ~49.5 M sat
About this peer Hybrid pricing — 1 sat base + 100 ppm — so the effective cost is ~1 sat per payment for typical receive sizes and stays close to that even at 1 M sat (the 100 ppm is mild). 100% enabled outbound and a high per-HTLC cap make it route-reliable. Geographic standout — sole African peer in the list, valuable diversity if any of your paying nodes happen to be in af-south-1 or want a short-RTT southern-hemisphere hop.
14. points-nexus
Pubkey 0379dbd35a22abe30d87f89664bad7aea31e4ba15a2e69ec4946113cfb9843c445
Socket 54.214.32.132:20147 (AWS us-west-2, Oregon — non-standard port)
Channels (gossip) 52
Capacity (gossip) 31.80 BTC
Outbound enabled 52 / 52 (100%) — every edge active
Typical fee_rate_milli_msat 1,300 ppm (median; min=1, max=1,300 — near-uniform)
Typical time_lock_delta 144 (median; min=80, max=144)
Typical max_htlc_msat ~49.5 M sat per HTLC (median); up to ~297 M sat
About this peer Combines a 1 sat base and a 1,300 ppm rate — expensive both ways. For typical sub-10k sat payouts you’d pay ~1 sat per payment (base-dominated). For larger payments the 1,300 ppm rate dominates — at 1 M sat this peer becomes pricier than Chessa. On the plus side: 100% enabled outbound and the largest per-HTLC cap of any peer in the list (~50 M sat median).
15. Chessa ✨
Pubkey 03f4553a2e6092fb7c03e7c4041451d9946e7326f6bf2c852278dacbaff798a4b3
Socket 54.71.27.149:20367 (AWS us-west-2, non-standard port)
Channels (gossip) 31
Outbound enabled 27 / 31 (87%) — healthy router
Typical fee_base_msat 1,500 msat (median; min=0, max=2,000)
Typical fee_rate_milli_msat 326 ppm (median; min=0, max=5,000)
Typical max_htlc_msat ~9.9 M sat per HTLC (median — high cap)
About this peer Different fee model than most peers above — a high base fee dominates the cost for small payments, so the effective rate is roughly 1.5 sats per payment regardless of size up to ~100 k sat. The 87% enabled-outbound ratio means they actively route, and the high per-HTLC cap (median ~10 M sat) makes them well-suited for larger payments where the flat base becomes negligible.
Caveats
Gossip lag. Once you open a channel with one of these peers, your
own LND won’t see their outbound-to-you policy in gossip
until they advertise it (usually within 24–72 hours of the channel
confirming). Until then, payers can route to you on a default policy
which may differ from the typical numbers above. Reverify after
gossip catches up.
Snapshot staleness. Every number in this post reflects the public
gossip view at the snapshot date. Channel counts, fees, and outbound
enable rates change. The longer it’s been since the snapshot date, the
more you should reverify (use a public node explorer like Amboss,
LightningNetwork+, or your own node’s describegraph).
Outbound enable rate ≠ guaranteed routing. A peer with 100%
enabled outbound is well-behaved by gossip convention, but nothing
about LN’s protocol prevents them from selectively rejecting HTLCs at
forward time. The empirical rate of enable in their gossiped policies
is the best signal available without actually sending payments through.
No endorsement. These peers were selected on empirical
small-channel-acceptance and on connectivity / fee criteria — not on
operator identity, jurisdiction, or anything reputational. If a
particular operator’s hosting, AS, or jurisdiction matters for your
threat model, do your own research before opening.
Reverify before opening. A 30-second sanity check with lncli getnodeinfo --include_channels <pubkey> or the equivalent on your
node software will tell you whether the peer is still online and
whether their advertised channel count / capacity is in the same
ballpark as what’s tabulated above. If anything looks drastically
different, treat this list as suggestive only and look for newer data.
Of course, there is also the Megalithic small channels node which we frequently discuss on the forum. I didn’t include it in my above analysis since I already had a channel with it on my test node (bit of an oversight, sorry)
Thank you. Really informative and timely. A fare bit to get my head around with ‘gossip’, ‘base’, ‘ppm rate’, ‘HTLC’, ‘outbound enabled’, ‘active edge’, CLTV’, ‘non-standard port’, ‘routing posture’ but as the old adage goes… ‘do hard things’.
I like the idea of building into geographically spread connections.
