Lightning Fork Swap
I ported Boltz to the BLAKE2b chain, and it is available at https://lightningfork.com
The primary use-case of course is to easily create inbound liquidity: Open a channel, send sats back to the on-chain wallet using this service, open another channel, rense, and repeat until you have the amount of inbound liquidity you want.
Um. A lite bulb moment.? I can send LND/CL sats (sha256) to my Blake2b wallet in your Lightning Fork. Yes?
Technically yes. But I would recommend first sending them to a new hot wallet, then send just the BLAKE2b sats (with replay protection checked) from the hot wallet in Shrike to Lightning Fork. That way you can move the SHA256 sats out of the hot wallet and into one of your main wallets on the SHA256 chain.
Let’s gO, pAUL! When can we watch your youtube video?
