Hashrate Autopilot
Found this very interesting repo on Github: GitHub - rdouma/hashrate-autopilot: Personal-scale autopilot and monitor for the Braiins Hashpower marketplace · GitHub
It’s CRAZY the amount of work that’s gone into this project not just from a features perspective but also a documentation perspective and it seems like it’s all from just one guy. It’s a bit suspicious to be honest but it seems like a lot, if not all, of the documentation was done using Claude so that may explain some of it.
Curious if anyone has seen this project before and what you guys think of it.
Claude is definitely an excellent way to increase your velocity as a developer. The main issue with it, however, is that it will amplify any bad habits that a dev has. A couple of smoke tests that you can run on a repo using your favorite frontier coding LLM to guage how careful a dev has been:
  1. “Please do a careful analysis of the project’s test suite, and give me a detailed summary of coverage and quality of the tests. Create a document with a detailed implementation plan for increasing test coverage and quality.”
  2. “Please do a thorough security analysis of the project, and if any issues are identified, give me a summary and create a document with a detailed implementation plan for addressing them.”
Of course, you don’t actually need to run the implementation plans, but telling the LLM to create them forces it to pay closer attention to the code, and helps avoid false positives in the summaries. If the test coverage is low or any critical security gaps are identified, then you know the dev probably hasn’t been careful and you may want to proceed with caution if you are planning to use the application.
I haven’t looked at this particular project – the above advice is more general for evaluating AI-assisted projects.
Those are great prompts and great advice. I actually had two separate LLMs look over the repo to see if it could identify any red flags and malicious code and both returned with favorable results. After doing a quick spot check auditing myself, it seems legit enough so I ran it and so far its amazing!
The main reason why I’m still hesitant and cautiously optimistic about this project is because it’s so good that I find it hard to believe that one person put this much effort and was able to create such a polished product without asking for compensation and without anyone seemingly knowing about it.
Thank you for the kind words! I’m the developer of Hashrate Autopilot. Very nice to hear the work is appreciated! And yes, I am doing it all with Claude. I basically manage my Claude agents as I manage a human team. It’s still a lot of work though, but it’s a passion project so that’s ok. If it helps more people mine at home and decentralize Bitcoin, I’m happy.
I agree. Claude is amazing, but if you don’t know how to frame specifications or have no way of verifying its output it’s not going to get you beyond simple prototypes. My personal approach to agentic development is to treat agents like “smart juniors” and manage them as I would a human team, making architecture decisions, making sure specifications are clear and continuously updated, QA, cross checks, keeping docs and code in sync, issue management, choosing priorities and planning accordingly, breaking tasks up in manageable pieces etc. When used correctly, it’s an enormous force multiplier.
