HashGG on Umbrel
Hey Paul,
You know it was coming!! Just saw Matt’s video and your tunnel tool was called out! Congrats!!!
I’m not on Start9, but on Umbrel, but would love to get this tunnel set up. Is it compatible, or available on umbrel?
My own setup is a little tricky. My ISP won’t provide fixed IP, and inside on NAT, and I have a Unify gateway inside my network. So, tunneling out seems to be the only way to manage this. Even the DDNS on the unify router won’t work because of the double NAT. :frowning:
So, any help is appreciated!
Paul
Yes, I am building an Umbrel version and a Docker version (to run on Linux, Mac, or Windows). Stay tuned.
So HashGG is the route to take I suspect for creating a tunnel then? Seems easy enough. I hadnt realized you had released it.
Yes, I’m planning to do a more detailed video where I officially release it (which will include the anonymous VPS setup for those who are concerned about privacy). Matthew asked if he could include it in his video today, which I think is a good idea (even though it isn’t perfect yet), just because the alternate methods are technically challenging for most. The drawback is now the spotlight is on me to make sure this thing is solid and reliable :smiley:
And undoubtedly it will be :+1:
I do think I’ll hold of on the request I made to you in DM last week and see what transpires at the public level. What Matthew demonstrated seems pretty straight forward (although he used beta 0.4.0). my take-a-way from that assume that you have to open a port if you run the app on 0.3.5~1?
Definitely will watch your (spaces) for a follow up to this as it is on my MUST do list..NOT maybe list.
Umbrel community app store now available here.
One important note – make sure you configure your Bitcoin address that you are using for Ocean in the Datum app. Unlike on Start9, this is configured in the Datum UI itself on Umbrel.
Any plans on having HashGG show up in the official umbrel app store?
Probably will look at getting it listed once I finish with the last couple of features I’m working on and everything is stable and in the maintain phase. That way I can avoid needing to submit a bunch of frequent updates for review while things are in flux.
I’ve decided to put my Bitcoin+AI video on hold for a little while just because it is taking a way longer to finish than I initially anticipated, and it is starting to feel like I have left the anti-spam arena for too long. So, planning to pivot and record some BIP-110 related videos before I get back to it. A tutorial on HashGG (which will include setting it up on Umbrel) is going to be the first of these videos I’ll tackle. If anyone has some specific items they think I should cover in the video (maybe something that tripped you up, etc), let me know.
Big Up Paul!
Just watched MK’s vid.
Respect
Just wanted to give a big thank you to you @paul for making HashGG available on Umbrel. I was finally able to get the Braiins Hashpower going with Bitcoin Knots on Umbrel with your app’s help. I am mining away with rented hash as I type this.
