Garbageman Nodes Manager on Umbrel
I’ve finished implementing the Umbrel wrapper for Garbageman Nodes Manager.
It can be accessed by adding the below URL as a Community App Store on your Umbrel:
https://github.com/paulscode/garbageman-nm-umbrel.git
Unfortunately, Umbrel doesn’t have a proper app configuration management system like Start9 does (it expects the apps to handle this themselves). So for now, I had to hard-code a password (I used “garbageman”). I’ll clean this up and add a dialog in an upcoming release which makes you change it on first login.
I’ve finished implementing support for aarch64 architecture and added the password update feature. I submitted a PR to have the app added to the Umbrel app store. Will keep everyone updated on the review process.
Alexander did a pretty thorough review of the PR (focused mainly on the wrapper, of course), with lots of requested changes. Most are straight-forward, but some will have impacts on the Start9 wrapper that will need to be de-conflicted, and one requested change that I think may break the Import Artifact from GitHub feature (will need some testing).
I don’t know yet how much flexibility they will have if I push back, so I’m planning do my best to make all the requested changes, with custom workarounds as required. I’ll try to keep the scope of any disagreement as small as possible, to hopefully improve the odds of getting listed on the app store.
It does not work on my umbrel.
It starts downloading and after 1% it stops.
The app or the import artifact from GitHub?
What device are you running Umbrel on?
I am running Umbrel using Umbrel Home.
In the below video you can see what is happening.
Umbrel Home has similar specs to the GMKTec G3, so from a hardware perspective it should be compatible. That behavior I have seen before when the tag referenced is missing from Dockerhub. I’ll check on that when I have a chance.
any progress here or is there a different solution to this?
Sorry, I have been focused on getting another big project off the ground (which I’ll be announcing soon), so haven’t gotten back to the nodes manager. I’m pretty sure I know what is causing that bug, so I’ll work on it next.
Just confirming, while downloading the assets to Umbrel on Rasberry Pi, I was alsso getting timeouts.
Sorry, I haven’t done any work on the app for a while. I’ll get back to it after I finish with the current project I’m working on.
