Garbageman at Scale: Introducing Nodes Manager on Start9
I published another Bitcoin-related tutorial .
In this video, I demonstrate a number of updates made to the Garbageman Nodes Manager since my last video, and how to install and use the tool on the Start9 operating system.
Unfortunately, for the last couple of videos, Youtube has been doing some shoddy post-processing that overlays the wrong section of the video over the audio for a few seconds randomly throughout the video before glitching back to normal (most annoyingly, this happened at the very beginning of my last two videos…) These glitches are not in the original that I uploaded. If anyone has some ideas for how to avoid this happening upon upload to Youtube, let me know.
I noticed a Hotfix Release : v0.1.1.0 - Hotfix: Instance Startup Failures on Github (I have had a failed instance when running v0.0.0.1)
I cant verify( PGP Verification) of the download for the hotfix files. Do I need to? Up grade = uninstall -reinstall?
Yes, the very first version had a bug where after I removed the pre-release assets that I used for testing, it would show some message like “failed ot start instance” when you click on the start button (basically I had a folder name hard-coded and overlooked it). You will need to delete the affected instance and upgrade to the hotfix version, and then create a new instance. You could also just uninstall the service and re-install (you’ll just need to import the artifact again if you do that).
The hotfix should be properly signed, let me check if there is a problem with it.
Oh, dang. I must have uploaded the wrong signature or checksum. Thanks for catching that!
Ok, new signature file is up. I think I must have copied the one from the previous version by mistake.
Must be my dyslexia. 0.1.0.1 looks awefully similar to 0.1.1.0…
All is working fine with hotfix. :+1: Thanks
At least that was a good test to see if anyone was paying attention :sweat_smile:
Thank you for all of the work you’re doing Paul!
I initially tried to get virtual box running but ran into partition issues.
I was able to watch this video and get it working within about an hour. My mini pc can run 4 or 5 instances without crashing. I’m also running a full Knots node and mining to Ocean with it.
I was able to do it all via an iPhone. The ui is a little buggy but usable.
I’ve discovered 6 LR/GM so far. All clearnet.
I’m looking forward to being able to preferential peer with v30.
Are you planning to implement a way to share our peer discovery findings?
That’s an interesting concept. I’ll have to think on how that would be implemented in a trustless way, though. If it were just simply sharing peer discoveries among the network of Corehort runners, then that would open up an attack vector for bad actors who could flood the network with fake addresses and degrade its usefulness.
I’ve finished implementing support for aarch64 architecture, and have applied to Start9 to have the service added to the Community Registry. Will keep everyone updated on the review process.
Matt Hill reached out to me on my request to be added to the Community Registry. His questions were primarily centered around use-cases, dependencies, resources requirements, and the extent of my testing. He did not yet make any specific change requests. I answered all of his questions, and he said he was digging further into the upstream project and would let me know if he had any further questions.
My sense from the focus of Matt’s questions was that a little more targeted documentation around resource management, IBD orchestration when multiple nodes need to sync, and possibly some visualizations of system resources may be requested before the listing is added. I’ve already started working on these updates in anticipation.
Would/could a BIP110 node specifically show up in peers or would it be denoted as Knots? My first thought is no because BIP110 was created after your build was configured… or maybe just listed under other. :thinking:
BTW- any progress in regards to the Community Registry?
Yes, I have plans to add some BIP110-related enhancements to the nodes manager. For Start9, Matt Hill got back with me and said they are not currently reviewing registry requests until after 0.4.0 is released (sounds like they are all hands on deck for that). He said they will definitely review the request after though.
I’ve recently added garbageman to my linux mint installation via docker. Looks great.
Couple of questions:
Why am I not seeing any LT nodes connected - I can see Knots, Core v30+m older core, other, but not LR. Have they masked themselves somehow?
I think you may have mentioned it, but is it possible to get into the config of the nodes - to apply my own config - especially for the knots instances.
They usually take a while to find. It is possible that Peter figured out a way to detect GM nodes. I’ll look into it to see if there is any recent information about it.
Not easily (technically it could be done by SSH’ing in). I’ll add an interface this in the next release.
Hello,
Just wondering how you’re coming along with the next release and will it be available for startos 040?
