Electrs Pruned + SHA256 Knots Companion – Sparrow cannot load old Trezor transaction history
Hi Paul, and others,
I’m trying to use a Trezor Safe 5 with Sparrow, while keeping the entire Bitcoin backend on my own StartOS server.
My setup is:
Bitcoin Knots (SHA256) Companion → Electrs Pruned → Sparrow → Trezor Safe 5
Configuration/status:
  • Bitcoin Knots (SHA256) Companion is fully synced
  • Knots is running pruned at 5000 MiB
  • RPC Proxy reports ready
  • Electrs Pruned 0.11.1:39 is fully synced
  • Electrs is connected to the SHA256 Knots Companion
  • Sparrow 2.5.5 connects successfully to Electrs over SSL
  • Sparrow detects and imports the Trezor Safe 5 correctly
The problem
Sparrow can open the Trezor wallet, but it cannot load its historical transaction history. It eventually reports:
Error loading transactions: Failed to subscribe to paths
and:
Error retrieving wallet history
At the same time, Electrs Pruned logs errors like:
failed to fetch pruned block ... over RPC
an RPC provider that serves pruned blocks (e.g. btc-rpc-proxy) is required
followed by:
Couldn't connect to host: Resource temporarily unavailable (os error 11)
My assumption is that Sparrow/Electrs finds historical transactions belonging to the wallet, but the corresponding blocks are older than the data currently retained by the 5000 MiB pruned Knots node.
As I understand it, Electrs Pruned is specifically designed for this situation: when an old block has already been pruned, it should retrieve that block on demand through the RPC proxy and verify it against the known block hash.
In my case, that on-demand retrieval appears to be the part that is failing.
Question:
Is this expected to work with Bitcoin Knots (SHA256) Companion + Electrs Pruned, and if so, what should I check to get the RPC proxy to successfully retrieve these old pruned blocks?
My goal is simply to have Sparrow display the complete history of my Trezor wallet using only my own StartOS backend, without switching Sparrow to a public/external Electrum server.
I’d prefer to keep the node pruned if possible rather than downloading the full blockchain again.
I think this is probably a timeout in Sparrow itself (which I fixed in Sparrow BLAKE2b but that doesn’t help folks on a pruned SHA256 node). Let me see what I can do in this setup.
Thank You Paul,
yes that make sense and we can use the trezor without history.
not that important.
Check the latest version of Electrs Pruned. I add a couple of optimizations to reduce the time on these calls. I have a couple more I can do, so if it isn’t working yet I’ll do some more work on it.
We do run the latest version and it seems working without the history.
I assume this means it is not working (since it should show historical transactions). I’ll keep digging. Anything new in the logs that seems interesting?
These logs goes above my head :slight_smile:
2026-09-22T13:04:30+02:00 [2026-09-22T11:04:30.124Z WARN electrs::electrum] RPC blockchain.transaction.get failed: failed to get transaction info: JSON-RPC error: RPC error response: RpcError { code: -5, message: “No such mempool transaction. Use -txindex or provide a block hash to enable blockchain transaction queries. Use gettransaction for wallet transactions.”, data: None }
2026-09-22T13:08:26+02:00 [2026-09-22T11:08:26.329Z INFO electrs::index] indexing 1 blocks: [968136..968136]
2026-09-22T13:08:26+02:00 [2026-09-22T11:08:26.382Z INFO electrs::chain] chain updated: tip=0000000000000000000148c293f2c4cfd9aebbe881e25b7159f5eea095ee27b1, height=968136
2026-09-22T13:26:03+02:00 [2026-09-22T11:26:03.591Z INFO electrs::index] indexing 1 blocks: [968137..968137]
2026-09-22T13:26:03+02:00 [2026-09-22T11:26:03.645Z INFO electrs::chain] chain updated: tip=0000000000000000000028042756cb14dd572dd63dd83bc58431d73bf1179ac6, height=968137
2026-09-22T13:39:45+02:00 [2026-09-22T11:39:45.122Z INFO electrs::index] indexing 1 blocks: [968138..968138]
2026-09-22T13:39:45+02:00 [2026-09-22T11:39:45.160Z INFO electrs::chain] chain updated: tip=0000000000000000000020c231d1f3c41171a8e9bb22551c81a38f0777a2f91e, height=968138
2026-09-22T13:45:41+02:00 [2026-09-22T11:45:41.705Z INFO electrs::index] indexing 1 blocks: [968139..968139]
2026-09-22T13:45:41+02:00 [2026-09-22T11:45:41.749Z INFO electrs::chain] chain updated: tip=00000000000000000000af04627edbf71ab1a4d30ca87af7ac8fc60502645643, height=968139
2026-09-22T13:58:00+02:00 [2026-09-22T11:58:00.817Z INFO electrs::index] indexing 1 blocks: [968140..968140]
2026-09-22T13:58:00+02:00 [2026-09-22T11:58:00.860Z INFO electrs::chain] chain updated: tip=0000000000000000000037a8683413c8dde7a65ebc4b0e839241f8fae72d240e, height=968140
Couple of questions:
  1. Is all history missing, or only transactions after August 8 (or is all the history before that date)?
  2. Is Electrs Pruned pointed at Bitcoin Knots or at Bitcoin Konts (SHA256) Companion? (Actions & Config > Select Node)
One test for pruning being a cause: In Sparrow, with your server connected, press Ctrl+I (Cmd+I on macOS), or use File → Open Transaction → From ID…, and paste this transaction ID:
a1075db55d416d3ca199f55b6084e2115b9345e16c5cf302fc80e9d5fbf5d48d
That is a well known transaction from 2010. It is not yours and reveals nothing about your wallet. It is old enough that your node has certainly pruned it, so fetching it exercises the same path your history uses.
Tell me which happens:
  • A transaction window opens showing 10,000 BTC sent in May 2010. Then the server is healthy and the problem is narrower than it looks.
  • “A transaction with that ID could not be found”, or an error. Then the server’s index is the problem.
Either way, please also stop Electrs Pruned, then start it back up and download the logs (Logs > Download). Send it to me in a DM (don’t post it here on this thread in case there is any privacy information)
Good moring from the Netherlands,
  1. This morning to my suprise there is a history of transactions in Shrike and Sparrow. See the pic of the shrike wallet with yesterdays test transaction. We see the transaction but the UTXO is empty. This is likewise in the Sparrow wallet.
  2. Yes Electrs pruned is pointed to Knots (sha256).
The test works well see pic. with the 2010 transaction.
The question remaining now is why is there no UTXO history?
Today we will setup the Trezor connection with Sparrow and Shrike to continue the journey.
We can do it !
Plural
<images redacted for privacy>
It is working after it takes a while loading in Sparrow but now we have history and UTXO’s from de Trezor.
<image redacted for privacy>
We moved over to our main topic above: Safely Moving Pre-Fork BTC to XBT
Ok, cool. So it seems like the remaining issue is the slowness, and that there isn’t any indicator when it is still working. I’ll take note of this. I can update it to be more informative in Sparrow BLAKE2b while it is busy working, but I can’t change upstream Sparrow or Shrike. I’ll put in PRs for them with the changes, and maybe they will be included in future versions. Sparrow wasn’t originally designed to integrate with an indexer on top of a pruned node, so some of the UX is bad in this setup because of the slowness when accessing data that has already been pruned by the node.
