Braiins Hashpower
Just to clarify one point, in this setup, OCEAN would be generating the block templates (not Braiins). However I think your conclusion is still correct, since OCEAN is not yet signalling for BIP-110 (I believe they are running Knots though)
Interesting options some of which is currently out of reach for level of technical know-how. I’m currently hashing to Ocean and intend on graduating to my own Datum Gateway. If I’ve understood currently solving a block the only way to signal for BIP-110
I’ve got about 6million sats on lightning that I’d like to start cycling through and signal for bip110. Is paul going to create a video soon about the easiest/reliable way/s to do it?
Yes, I’ve built a tool called Agent Wallet which simplifies the process of depositing to Braiins from Lightning or from on-chain routed through Lightning (to avoid being flagged for review). I’ll be recording a video about it soon.
In the meantime, the manual process is to do a swap from Boltz.exchange (lightning to BTC) to a fresh unused Taproot address, then send that to Braiins. If you are using RTL for this, you’ll want to do a Sweep All to a new Taproot address first before doing the Boltz swap (because in RTL you can’t select specific UTXOs when sending an on-chain transaction)
Interesting. I do the latter as well with Boltz > Onchain > Sparrow > Brains.
Are you using any part of the hashpower api?
Ive been working with the api to manage orders from local. I just cant get Claude to help me properly get it into my Dashboard I built. Guess Im going to have to brush up on my manual coding again and find the errors myself. Driving me nuttso.
Mock-up
Not for Agent Wallet. I will be for a future project I’m still thinking through though.
Very nice, I’ll keep an eye out and thanks for the info
Just posting here to have something in the forum.
Cool, any luck after refreshing the page?
posting to get DM’s trying to get this to work for a private chat with Paul
Hi Paul. It’s Dan Kypena again. We worked together to try to get my Start 9 server up and running without success last month. I was about to move and then had to travel out of country for the next few weeks so I just got back. My new apartment has much better internet connectivity.
I would very much like to work on getting my Start 9 server up and running again with you. In addition, I just this morning learned about the Cold Card issue and am very concerned because I use a Q with a seedphrase generated by an MK4. I’m looking for assistance to secure my funds which is actually a bigger deal than the node right now. Can you please let me know when you would be available for a call with me?
Thank you kindly sir.
Dan
I’ll be AFK until next Tuesday. Send me a DM with your availability. I’m typically available after 6:00 PM Central and any time on the weekends.
