Bitcoin Knots 29.4.3
Release notes
xbt.live coverage
Are there plans to update Blake2b Companion before 10/31 so we can have a 29.4.3 node running by block 979,919? Many thanks Paul!
I’ve been asking in the Discord but I cant get a reply so I’ll ask you…
Does 29.4.3 need to be side-loaded or will it be available in the Start9 Custom Registry (start9.mempool.guide)?
Edit: I see a comment from the xbt live coverage that states -
Wait for the official download at bitcoinknots.org/files/29.x/29.4.3.knots20260508/. It wasn’t posted when we checked on Oct 27. Don’t run a build from anywhere else.
i dont have a concrete answer but because this change is important I think the custom registry is going to have the update before the coinbase maturity change is going to hit.
its in the registry now
The Companion app is also available now in my registry.
Yeah. I don’t see it in the start9.mempool.guide registry.
EDIT - apparently it does have to be side-loaded. Missing verification key with this
I was able to see it and install it from the registry shortly after the update was released. Not sure why you didnt see it there. Someone mentioned refreshing the browser might fix that
Yes, a problem with Start9 at least is that updates don’t show until the page is refreshed. I should submit a PR to fix that..
Reason I didn’t see it:
Mechanic slapped me around on the Discord. Start OS needed to be updated. Knots v29.4.3knots20260508 is not see-able in the market place on version 0.4.0.1
Issue resolved.
EDIT - Yeah. Now Tor is not responsive. One of the reason I dont update right away because of issues like this. SparrowBlake2b wont connect now. Back to the drawing board.
SparrowBlake2b reports -
This version of Tor will not work as a client on the Tor network. The missing protocols are: Desc=3 Microdesc=3
RealTorCtrl[fid=F113…7D7E]@1902729980 End Of Stream
RealTorCtrl[fid=F113…7D7E]@1902729980 Stopped Reading
RealTorCtrl[fid=F113…7D7E]@1902729980 Connection Closed
RealTorCtrl[fid=F113…7D7E]@1902729980 Scope Cancelled
RealTorCtrl[fid=F113…7D7E]@1902729980 Invoking onDestroy callbacks
RealTorCtrl[fid=F113…7D7E]@1902729980 Closing Dispatchers
RealTorCtrl[fid=F113…7D7E]@1902729980 Dispatchers Closed
my tor version is 0.4.9.14:2
Is this yours?
This is fixed in the latest version: https://github.com/paulscode/sparrow/releases/tag/v2.5.6-blake2b.7
BTW, Sparrow upstream (and Shrike) had the same problem, and have also released fixes in their latest versions.
