I work from a converted attic room in New Jersey, and the winter drafts make it hard to keep my desk area comfortable without heating the whole house. I’ve been looking at compact PTC space heaters around 1500W, the kind with a ceramic element and a fan, since they seem to warm up fast and fit under a desk. The thing I can’t work out is whether the fan noise would be distracting on calls, and whether a 1500W unit on a standard 15A circuit is safe if it’s sharing an outlet with my monitor and laptop dock. I’d also like to know if the thermostat actually holds a steady temperature or if it cycles on and off noticeably. If you’ve run a small PTC heater in a similar room, how has it worked out for noise, power draw and comfort?sey, and the winter drafts make it hard to keep my desk area comfortable without heating the whole house. I’ve been looking at compact PTC space heaters around 1500W, the kind with a ceramic element and a fan, since they seem to warm up fast and fit under a desk. The thing I can’t work out is whether the fan noise would be distracting on calls, and whether a 1500W unit on a standard 15A circuit is safe if it’s sharing an outlet with my monitor and laptop dock. I’d also like to know if the thermostat actually holds a steady temperature or if it cycles on and off noticeably. If you’ve run a small PTC heater in a similar room, how has it worked out for noise, power draw and comfort?
Update after looking around more - JIBUFI PTC-903A 1500W Portable Space Heater Review kept coming up while I was checking fan noise and thermostat behavior. Still not sure the fan would stay quiet enough on calls, and I’m cautious about sharing a 15A circuit with my monitor and dock.
