Sparrow and Shrike not connecting at all
I can not get connected on Sparrow nor Shrike as it says Could not connect:
Tor socks proxy is not yet instantiated.
What happened?
The thing is this must be a general hick-up as I got disconnected before I updated to v 0.4.0.4 and on the Public servers, it keeps alternating with connection probs.
Is this a general Tor Proxy problem?
The bundled Tor 0.4.8.21 stalls at 30% since nodes now require descriptor protocol v3. I’m building a fix. I think Shrike has fixed this as well in latest version.
The new updated versions of Shrike and Sparrow do work now with the .onion links from Start9, but, after the new updated version on Start9, v0.4.0.4, the Marketplace Registries don’t allow any Updates, Switches, nor new Installs on any registry other than the main Start9, not even the Community Registry is being allowed to function. Do I need to trust your signature anywhere on Start9? How? Otherwise, when any update comes in for i.e. Blake2b Companion freom your Registry, it will soon be out of date. The new Updates for Lightning Fork, etc, ythree or four can’t be “updated” on Start9. How do we get this back again? What is Start9 up to? Are they going full head-on BTC Core-Chain from now on?
This is a security feature (and trust me you will be happy it exists if AI keeps getting stronger). The scenario is that an AI hacks into my registry and replaces one of the apps with some malware without me noticing. If that happens, now Start9 will notice and not let the app install, because it would no longer have a trusted signature.
I am having issues connecting Sparrow to my node running Knots (pre-RDTS) 29.3:31, Fulcrum 2.1.4:0. I am receiving the following error “650 ERR At least one protocol listed as required in the consensus is not supported by this version of Tor. You should upgrade. This version of Tor will not work as a client on the Tor network. The missing protocols are: Desc=3 Microdesc=3” Currently running Tor 0.4.9.15:0 which I believe is the most up to date. I have updated to the latest version of StartOS 0.4.1.1 and added Paul’s Trusted Key. Any ideas to why I am unable to established a connection with Sparrow and my node?
First, update Sparrow to its latest version and try again connecting to Electrs or Fulcrum. Plus, I had to go and switch to Bitcoin Core for Electrs and Fulcrum to work on the main chain. Other than that I updated to the latest Shrike wallet on desktop and that can be used with Electrs Pruned (Paul’s code) and Blake2b (Companion) Knots from Paul Lamb. I found that something went on with Tor and now, not even the Ashigaru mobile wallet manages to “initialize” Tor at all. Neither Ashigaru from the Community Registry. Tor has changed something that those devs have to update to. But @paul is the best person to let you know which way to go. Best of luck!
You need to update StartOS.
Not necessary. I’ll have a newer version of Bitcoin Knots (SHA256) out later today which supports the latest comms protocol. Please do not run Core unless you are in an emergency and need to send a private on-chain transaction immediately (in which case switch back to Knots as soon as you can after). Those guys do not need the extra ego boost they already got when they ran off their opposition.
Alright, Paul. Is it out yet? We just withdrew our last 70 buck$ from Binance (JUST IN CASE) and they ate up our XBT from the old deposit! Haha! No need to replay protect that one! But we got it OUT! We will need a Replay Protection course soon, now that we are running Shrike’s latest version but we need the Coldcard-Shrike implementation or a Seedsigner loaded with our Coldcard (old) seed, luckily it survived! When have you any more videos coming out on these subjects? Many thanks, again! Not.Me. Your email reply was very useful too.
It is build and ready to publish. Github is having an issue currently (uploads are running at like 0.7 Mbit/s. and dropping like 15% of packets), so waiting for that to clear, then I’ll push the release.
Kool. Publish. I followed you on Github. I am the one with the Teddy Bear profile. R. u. A. I.
It is published (Start9 and Umbrel)
Updated StartOS to v0.4.1.2 and the issue resolved. Thanks Paul. Cup of Coffee sent.
WOW! Get up in the morning and StartOS has another Update 4.1.2, now! Phew! Done! Yours good! Tor wasn’t working but after a few restarts it seems to be on ok. Many thanks. I will email you re: Lightning “cups of coffee”!
