The bridge status language has slightly changed. It says the bridge is enabled but cannot start, and tries again every 1m0s: the SHA256 Lightning node does not answer: rpc error: code = DeadlineExceeded desc = stream terminated by RST_STREAM with error code: CANCEL
The new wording only means the bridge gave up after 30 seconds: your SHA256 Lightning node is running, but it’s waiting on your SHA256 Bitcoin node, which isn’t answering it quickly. Could you check and send me a few things?
Your SHA256 Bitcoin app: is it fully synced, or still syncing or reindexing after its update? Its version, and its health checks in StartOS.
Your platform (StartOS or Umbrel) and the Lightning Fork version.
The Lightning Fork logs from the last hour
The SHA256 Bitcoin app’s logs for that same hour.
If the Bitcoin app is still syncing or reindexing, the bridge will start by itself once it’s done.
Logs can be DM’d to me as .txt files (don’t post them here on the public thread).
Your SHA256 Bitcoin app: is it fully synced, or still syncing or reindexing after its update? Its version, and its health checks in StartOS. Bitcoin Knots (SHA256) Companion#knotsprerdts:31.1:3 fully synced
Your platform (StartOS or Umbrel) and the Lightning Fork version. StartOS
