HashGG 0.7.2:6 tunnel issues
Hi Paul/All,
I just tried to upgrade HashGG 0.7.2:6 from prior version on my Start9 StartOS 0.4.0.2. I have been using BitLaunch VPS which as been working fine for months prior to this latest HashGG update.
Now I see health check issue “The public address does not return stratum replies; miners will connect but get no work”
Logs noting “Health Check tunnel-stratum failed: The public address does not return stratum replies; miners will connect but get no work”
With the WebUI see Tunnel is Red w/ “Public address is not carrying stratum (connected, but no stratum reply within 8000 ms)”
Any Ideas?
Thanks db!
Update: Looking at DATUM Gateway and pool after some time, they do see the Hashrate from my remote miners (they are getting work). Therefore seems that HashGG showing false error?
Thanks,
db!
