DATUM Gateway Retropex
Datum Gateway0.4.1:15
In the Health Checks for Datum Gateway, what values do you see for these?
This message appeared after a Bitaxe software upgrade some time ago, and stayed present even when the device was hashing away as normal. A quick google will bring you lots of results.
Health Checks
Name Status
Stratum Interface Stratum server is available
Number of Stratum Clients Connected Connected Clients: 2
Estimated Hashrate Estimated Hashrate: 0.00 Th/s
Web Interface The Datum Gateway dashboard is ready
est. hash rate show 0.0 , but one is 1.91 ad the other bitaxe shows 1.82
What does it say under “clients” on datum gateway’s web interface?
unable to get to clients on the datum gateway web interface , username - password is incorrect
The username is usually admin, the password is in the Actions & Config section of your Datum service properties.
what info am I looking to see in the clients section , that tell me I am connected to my miners
The client list displays all miners that are currently connected and the performance metrics of each miner. If its empty then there are no miners connected.
No miner:
Miner Connected:
got it thanks , what is TID/CID , under command what is “Kick”
ID (Transaction ID) and CID (Coinbase ID) - TID is used to uniquely identify transactions being mined, while CID identifies the coinbase transaction that rewards miners for their work.
Kick is a signal that can be sent to the mining software to restart or refresh it. This could be used to make certain that the system is functioning correctly or to apply new configurations.
